Heres the specs of the psu :
1. Compliance with the newest Intel standard ATX 12V V2.3
2. More than 70% efficiency at typical load operation
3. High reliability (MTBF > 100,000 hrs)
4. Green power design to meet Energy Star and Blue Angel requirements
5. Silent operation with intelligent fan speed control
6. Multiple protection design(OVP/OCP/OPP/SCP)
7. Support dual +12V1 and +12V2 outputs for higher power usage
8. Two-year warranty
Model RS-460-PCAP-A3
Type Intel Form Factor ATX 12V V2.3
Dimension (W / H / D) Intel Form Factor ATX 12V V2.3
Input Voltage 180~264 V
Input Current 10 A @ 115Vac / 6 A @ 230Vac
Input Frequency Range 47 ~ 63 Hz
PFC Passive PFC
Power Good Signal 100 ~ 500 ms
Hold Up Time > 17 ms
Efficiency >70% Typically
MTBF >100,000 hrs
Protection OVP / OCP / OPP / SCP
Max. Output Capacity 460 Watts
Operation Temperature 0~40 Nominal Input Voltage
20+4pin Motherboard Connector x1
4+4pin+12V CPU Connector x1
6 Pin PCI-e Connector x1
S-ATA Connector x4
4 pin Peripheral Connector x5
That means nothing to me
So maybe a dual core , 2-4gb of ram and maybe sli? Or is it worth going for a 500w ocz psu?
Thanks guys - let the spending money spree continue
EDIT - excuse my ignorance btw!
PFC Passive PFC
MTBF >100,000 hrs
S-ATA Connector x4
