Exclusive! - Porsche 911 Wheel Turbo Wheel - Test Review!
Just to let you guys know, Fanatec say that the wheel has been completed and there are 40 changes that have been made to the product. They are:
Wheel:
Button illumination is disturbing -On PC the illumination can be turned off by driver
Wheel is moving to one side if you stop a game -Firmware change
Battery warning for pedals not working correct -Firmware change
Select / Start button not strong enough -Design change
some buttons shaky -Change Injection and assembly quality
Start/select illumination not easy to read -Add silicon light cap
Wheel is shaky on wheel axis -Adapt axis diameter to Wheel rim
Base:
Fan is too noisy -Change in Firmware. Fan operates at 50% speed and only increases to 100% under extreme conditions
RF dropouts -Change antenna design
Screws falling out -Secure screws with glue
Plastic caps on steel screws falling off -Change design of plastic caps
Cable to shifter falling out -Change quality of PS/2 plugs
Off centering issue I: Wheel is always a little bit off center -Change design and assembly of auto centering sensor
Off centering Issue II: Wheel looses center after fast movements -Change firmware / Improve quality control for optical sensor
Off centering Issue III: Wheel looses center after normal gameplay -Change firmware
Sparks when connecting power -Change PCB design. Long term: add switch
The position of the wheel rim is too high -New Wheel clamping system available as an optional upgrade.
Clamp system does not fit to some tables -New Wheel clamping system available as an optional upgrade.
Wheel angle is not adjustable -New Wheel clamping system available as an optional upgrade.
Pedals
RF dropouts -Change Antenna design
Pedal cannot be mounted on simulators -Add screw holes
Pedals too light -Add steel plate (1,1 kg)
Pedals slipping on flat floor -Add big anti slip mats
Brake travel too small -Increase brake travel 100%
Brake resistance not big enough -increase brake resistance 300%
Gas pedal resistance not big enough -Increase gas pedal resistance 50%
Cosmetic problems -Add rougher texture
Pedal falling over during heel & toe -Add steel plate which makes the pedal longer
battery difficult too install -Change design of battery contacts
cable to pedals too short -Increase length to 2.5m
pedals only reach 50% of the travel -improve assembly
brake spring not working smoothly -Change from extension spring to compression spring
Shifters:
2GS not working because spring jumped out -Change design
Appearance of shifter does not match the wheel standards -Apply soft touch rubber surface on all black parts of shifters
4th gear shifts too early / not possible to find neutral position -Change design
Electronic misshifts -Change design of potentiometer holder
Shifter attachment not stable -New Wheel clamping system available as an optional upgrade.
Possibility to mount the shifter to a simulator New Wheel clamping system available as an optional upgrade.
2GS mapping on Playstation is wrong -Inverse button mapping
Shifting to reverse is too heavy Change shape of PU foam to reduce resistance
even down to:
Packaging:
Shipping carton not neutral enough -Change artwork
p.s. sorry for the epic bump :o
My other account on here got suspended for reasons I have no idea why :(
I'm going to keep this one anyway now.
as for the wheel.
I recieved our email the other day,
thanking everyone for testing it, and they are letting everyone keep it.
I'm still probably going to sell it,
I got it boxed now, so if anyone wants to know more, email me.
hopefully a Mod also, can tell me the reason why my other account (CooliceT)
as been suspended on here... :/
as for the wheel.
How long have you been suspended for it was proberbly be a tempory thing and the new account you have just made will also most likely be suspended.
yea its only till the 28th but it says its removed my MM access...
and I have been suspended for silly things each time, which I guess... happens.
this will probably get suspended, but I cannot see why due to I'd rather keep this one now, to use with my website/name
is there mods? I could ask why and what reason they suspended me for?
and... its easter :(
where's... the happiness?
you'd think... this time of year....
Send them a message, but looking at your posts perhaps it was due to you offering an item for sale outside the mm. Pointless posting here asking why tbh and setting up a new account isnt looked on fondly by the powers at be either iirc.
If you have lost MM access on that account as well then it is because of something related to the MM that got you suspended, and creating a new account is only going to make things worse. You should have waited till the suspension was up then asked for a name change on your old account.
ah I should have done that NightSt@lk3r ;)
I dont like waiting, and still dont know why my MM access was removed though, and when it happens I have no way of contacting them / or mods who control that area to ask.
I cant read the last post I made... So I dont know if it was something I put or said...
anyway.
I'll best log off... and come back on the 28th, and ask any mods about to seek out a Name change, then they can delete this one.
and just swap the name over.
shame I loose MM access... but its not the end of the world.
I should pop on x-fire and see you Night :P
I keep forgetting to log on it.
have a good easter all. :)
