Does all 8800gtx cards have a black PCB ???
Am still trying to work out if i want to spend this amount of money on a GPU card that got released about 15months ago :confused:
Or should i wait a few weeks/months and see how much the new nvidia 9800 (GTS/GTX ?) gpu cards go for :confused:
(I don't want one of the new lego 9800GX2 ;))
I'd only look at 2nd hand GTX as there were a few went for £180. Truth is even after 15 months there really is still nothing on the market atm to completely replace the GTX apart from maybe the GTS 512mb but even that falls short in some games due to 256bit memory.
Also if rumour is to be believed the new 9800GTX will be based on the G92 GTS so won't be that much faster than the current 8800GTX I think.
Don't think it's gonna make THAT much difference unless you're running your pc is running 3D 24/7 tbh.
Besides you wouldn't even think about SLIing 8800GTX if power consumption means that much to you.
I do leave my PC running 24hrs a day a lot...
24/7 at idle = about £200 a year electric already (not counting speakers,monitor etc)...
I want to upgrade to a SLI & quad cpu but i don't want to have to pay a £300+ electric bill a year just for the PC..
the question that often doesnt get asked but should.. what do you even use your PC for, why would you concider SLI?
I cant remember what GTX I have but its definitely on a green pcb (I thought it was BFG -non OC version - but I cant swear to it
At work currently so cant check
Thanks for the replys guys.....
Am now trying to find another EVGA 8800gtx (with ASC cooler) to go SLI
:mad: But am not having much luck with finding one :mad:
