I've not even considered an LCD TV until recently but want something I can wall mount to save space and i'm looking to get a PS3 in the coming months, I'm after some help.
I'm probably going to go for a 32 inch screen, is this hands down the best telly for £400ish?:
http://www.overclockers.co.uk/showproduct.php?prodid=AV-033-SA
I don't need freeview really this screen is only going to be used for PS3/PC gaming and movie (PS3 Blu Ray or PC)
I loathe ghosting so want an honest opinion about how much of an issue this will be on any screens. I may go for 37inch if the price is right (<£500)
Previous CRT tellies I have been impressed by have been Toshiba and Panasonic so I would also consider those brands or maybe an LG.
I'm going to be hooking it up to a stereo amp (can't be faffed with wire for surround) either direct from the PS3 if poss or from my PC. Does optical out transmit a stereo signal if needed or just surround sound?
Are some decent swivelable
wall mounts you can also recommend?
Ok Go, recommend me some screens
Cheers in advance,
Cheers in advance,
