AHCI on Asus P5K Premium/WiFi-AP - HELP!
Hi Guys,
I’m currently planning on building the following:
Intel Core 2 Quad Pro Q6600 "Energy Efficient SLACR 95W Edition" 2.40GHz http://www.overclockers.co.uk/showproduct.php?prodid=MB-258-AS
I’m still undecided about the thermal compound.
Asus P5K Premium/WiFi-AP Intel P35
Western Digital Raptor 74GB X 2 (Planned RAID 0 config)
Antec Nine Hundred Ultimate Gaming Case
GeIL 2GB (2x1GB) PC2-6400C4 800MHz Ultra Low Latency
LiteOn 20x DVD+/-RW/RAM LightScribe
BFG GeForce 8800 GT
Tuniq Tower 120-LFB CPU Cooler (Socket 478/754/939/940/AM2/LGA775)
OCZ Technology StealthXStream 600W Active PFC
Arctic Silver 5 Thermal Compound
However, I’m now very concerned about the RAID compatibility of this board. I’ve never setup RAID before and would preferably like to setup my new computer without having to buy a PCI RAID card.
Now I’ve had a look around and I managed to find the following threads.
According to Schnippzle, you can:
“however its become apparent that I have to use the external sata port and one of the internal sata ports to get raid to actually work I’m planning on having both raptors internal and running an esata-> sata cable into my case and to the raptor to solve the problem of not having an internal RAID controller. Does any1 have any experience with this / what’s the performance like relative to native internal RAID support? Should I just invest in a RAID controller card or another mobo instead?”
And jbloggs:
“Enable the ICH9R in BIOS, Save & Exit, CTRL + I to enter RAID setup utility, set up RAID, name, stripe size etc, exit, reboot, re-enter BIOS, and make sure your Intel Raid volume is showing up in HDD priority, and is set as 1st, then make sure it is set as 2nd boot device, your DVD rewriter set as 1st boot device, Save and Exit, as you don't have a floppy (which is needed to extract the drivers from the floppy), simply boot from the Vista DVD (which has ICH9R drivers contained in it), as soon as it starts to boot, it will ask you to press F6 to specify another Device, so press F6, it will load files etc, then come to the agreement etc, it will ask you to specify the device where you want to install, choose ICH8R/ICH9R, then format etc, rest is the same as normal Windows install, when Desktop appears, 1st install Intel Chipset Software, then reboot and install the Intel Matrix Storage Manager...then at a later date, when you get a floppy you can update the ICH9R drivers...fin!”
Now the first work around suggests that putting one drive on the internal and then one drive on the external within a RAID 0 configuration is bad and that using a conversion cable is necessary to fix the problem.
The second work-around suggests that its ok to use an internal and external cable.
I really want to RAID 0 my build to get the most out of the raptors but don’t really want to change the MB as it appears that its one of the best all round boards for overclocking the G0s.
Can anyone help?
Hi Guys,
BFG GeForce 8800 GT
And jbloggs:
Can anyone help?
