if it was me i would go for the lian li and then get the window side panel . i think they look better though the styling of the soprano has never really done it for me ...
The Lian-Li does look better, looks better build quality. The only thing that puts me off is that its slightly smaller on the height. Need as much room as possible really.
Definitely the lian-li, I have had both cases and the quality soprano is nothing compared to the pc7. The lian-li will give you better cooling and won't have a flimsy plastic door on the front
I've decided against both. Thanks for the input though guys, I want to spend less money. I set the budget a bit high. I'm going for a CM Centurion 532.
