Just had a bathroom fitted by a builder, very nice job including plumbing, tiling etc. but there are two things foxing the builder and he nor I can figure them out.
Problem 1:
The toilet has a bit of a leak (fills about a mug a day!). The leak comes from the connection on the bottom left of the toilet as you stand in front of it, its a plastic pipe with a thread on it which runs from the toilet water tank, my builder has tried different nuts, plumbers putty and teflon without joy.
Problem 2:
The sink leaks from the trap, the builder tried a plastic trap initially but thought as the rest of the sink pipe was chrome, I should get a chrome trap as he thought the threads might be slightly different, I did this and he has tried rubber seals and teflon but it still leaks.
He is qualified and has fitted the boiler and central heating perfectly as a separate job. Any ideas, do you think he is doing something wrong as he is not refusing to give up but has hit a brick wall in terms of ideas?
Problem 1:
Problem 2:
