Question about Knights of the Nine and Shivering Isles
2 May 2004
Hi,
Just wondering if these expansion packs are an 'add-on' or a 'different game'.
e.g. will they add new towns to the current game that also give new quests? or will they make me launch a new client and create a new character in a different world?
Thanks,
Craig.
Nope, they just latch onto Oblivion and you can keep playing with your normal character, just like regular plugins :)
Nice, I don't really like expansions that are just a 'new game', much better then they're basically a big add-on. :)
What about Knights of the Nine for the Xbox360, how does that expansion work?
Thanks,
Craig.
Although they do both plugin I would say that Shivering Isles is a game in its own right. It adds an entire new land via a portal. Yes, you can use the same character as you do for Oblivion but it's completely unrelated otherwise, other than the existance of a portal.
Knights of the Nine on the other hand is a collection of all the official downloadables prior to Shivering Isles. There are quests but they are all short aside from the one in the title. Though the 360 version contains only the main quest. The others can be obtained individually by download, though it may be cheaper to sell your current game and buy the GOTY edition which contains everything AFAIK.
Oh, and a word of advice. My warrior character had become so strong midway through Oblivion that I walked through the expansions without even having to use potions or scrolls. Every enemy required nothing more than a few swings of the mace, and even the bosses went down like children. In retrospect, it would have been more fun to have cranked up the combat difficulty as The Elder Scrolls games never scale well as your character progresses. So if you are finding it too easy then I would recommend notching up the difficulty accordingly.
Was in Game today and saw that you can buy Shivering Isles with Knights of the Nine on DVD. I don't know if it also includes the other downloadables but must be worth checking. :)
I think for xbox 360 once the knights of the nine is installed and recognized it will give you a quest briefing in your journal on where to go, Shivering isles on the other hand requires you to seek out where to go by talking to town people (Or reading the interweb)
Nope - SI gives you a message after (IIRC) 24 hours of game time telling you that you've heard about a mysterious island in Niben Bay. It also places a marker on your map.
M
