Even though I'm the one pointing out that 99% of people get no use out of more power most of the time, its very true that people that need massive cpu power will be drooling at the thought of better chips.
However Nehalem is a ARCHITECHTURE that scales from 2-8 cores, its launching with 4 cores only, and only the extreme edition in 2008. Lower end quad cores in early 2009 which means more than likely 8 cored version not till mid 2009 at the very earliest. Not sure if they are planning 8 cores on 45nm , or if they are waiting, I think 32nm is the next stop? with the power of mem controller onboard 8 cores worth of power and mem controller on 45nm might be a bit OTT.
Skulltrail, as is, won't be available for Nehalem, certainly not at launch. Nehalem is on a bodged xeon chipset, the platform will need a new chipset and its very unlikely you'd get anything too soon. Yorkfield skulltrail, or any dual or more xeon setup is probably the best bet for pure power at the moment.
Anyone that recommends waiting for them for ANYONE who basically games, is giving crappy advice though. Frankly I'm not sure Nehalem will even be giving much of a performance boost at all over yorkfield, maybe better scaling when using that 4th core at 100% as 2 or 3 cores tend to scale very well right now, but the 4th maxed out, maybe slightly bandwidth starved by then.
