Fresh Vista Ultimate 64bit install - anything to know?
18 Oct 2002
Pembrokeshire
I'm upgrading my PC and have got a Vista Ultimate 64 for the OS.
This will be my first Vista install - only previous experience with Vista is un-installing it at work for XP :)
Is there anything I should be aware of before I start - or anything that might catch me out in the process?
Few things:
*Disable Aero effects for an increase in performance.
*Change the power saving profile otherwise it steps down your CPU when it doesn't THINK it needs to be used.
*Disable UAC if you think you dont need it (MS permissions system is a joke anyway).
*Install SP1 before your sound drivers etc. as there are a lot of incompatibilities being reported
*Try and install a firewall before connecting to any network (standard for all OS')
Cant think of anymore off the top of my head, there are loads of sites online with guides though
Few things:
I don't agree with those personally - Aero is one of the things that makes Vista nice to use. It's only worth disabling if you're on a slow machine, in which case Vista isn't the ideal OS to be using in the first place.
Power saving modes are useful, they reduce power usage and heat output. The CPU should always step-up to the full speed when it's needed.
UAC can be a pain, but use TweakUAC (google it) to set it to silent mode, rather than disable it completely.
Would agree with TheVoice on this one.
Also, the Vista firewall is more than adequate for the average home user, and if you're behind a router it's more than enough.
Got 2x 2 gig to go in going to do fresh install will it or wont it work?
Installing Windows Vista on a computer that has more than 3 GB of RAM, is a know issue, it might not effect you, it might, i would install with just one stick, just in case.
see the link for more details
i did my install fine, it then started BSODing on me, applied the patch all was good
I think you're getting confused, Windows 32bit has problems with RAM above 3GB. Windows 64bit has support for much higher amounts of RAM (128GB).
So if an SP1 disc is used to install Vista there shouldn't be any issues with 4GB of RAM?
yes i beleve it should be.
read the link, http://support.microsoft.com/kb/929777
APPLIES TO
• Windows Vista Home Basic
• Windows Vista Home Premium
• Windows Vista Ultimate
• Windows Vista Business
• Windows Vista Enterprise
• Windows Vista Starter
• Windows Vista Home Basic 64-bit Edition
• Windows Vista Home Premium 64-bit Edition
• Windows Vista Ultimate 64-bit Edition
• Windows Vista Business 64-bit Edition
• Windows Vista Enterprise 64-bit Edition
doesn't affect everybody, it did me, as i said it a know issue
i must say ive never heard of that issue. but hey its not exactly difficult to take a few sticks out for the install. might as well do it to save any possible hassle i guess.
Hello Xenoxide, crazyDAJT was not referring to how much a 32-bit Operating System can address but the problems that users have experienced installing Windows Vista with more than 2GB of RAM installed in their machine.
Though, I can't say I have ever had any problems installing Windows Vista with 4GB of RAM installed in my machine. :)
