So why are they there?
Emissions reasons.
[TW]Fox;11390773 said:Boost pressure through a swirl flap?
What about the turbo units which aren't known for being the best....
Surely under more pressure from the remap will increase the chances of failure?.
I also did not know this was the case. No need to be unpolite![]()
easyrider said:So why are they there?
I remove them?
What happens?
Nothing?
No loss of performance? Noise? Heat?
what?
They must be there for a reason? No?
Where did I mention swirl flaps in the post you quoted?
Is it legal?
What about MOT emissions tests?
[TW]Fox;11390785 said:Oh I see, so you've been proved wrong about those so you moved onto something else to try and get a bashing in. SighDidnt realise.
Yup - it's legal.
Will still pass MOT emissions. They are there to reduce CO2 emissions - only important for company car ratings.
Why doesn't every enthusiast remove them?
Tom|Nbk said:I don't profess to know a lot about the swirlflap issue.
Then stop pretending you do.
Oh do shut up, complete hater
Notice how you didn't make him aware of the increased boost with the remap. I did, no point saying it's ok everything is fine when it may not be, increased boost with the remap could shorten the life of the already weak turbo unit even more so.
I'm just trying to make Easy aware of some of the issues which could be amplified, hey OK I was wrong with the swirlflaps but these should be removed in any case. Putting them on just to get into a tax band knowing fine well they could fail down the line is a bit :/
Actually to be fair I doubt BMW expected them to fail that would be daft.
It's like a 12-15% increase on peak boost for most of the standard remaps. Diesel remaps increase fueling and barely touch on turbo boost - I.e. the additional wear on the turbo is negligible.
BMW put them in as they reduced CO2 emissions, they wouldn't have put them in if they realised they would cause catastrophic engine failure. It's pretty obvious now that they should be removed now, but a remap will make no difference whatsoever on their longevity.
Leave this thread now, you have proved your ignorance on the matter.
Once again you have reinforced your utter contempt of the 3-series BMW, offering nothing useful to the discussion.
Have emailed simon mate.
Thanks for the link.![]()
Tom|Nbk said:What has my contempt of the 3 series got to do with my advice on a remap. Which is proved to put extra wear on components. Everyone knows this.
OK so a 12-15% increase on the boost on an already seem stupidly weak (yes it really does seem that bad from what I've read) turbo could amplify turbo wear even more. It's pretty much fact a turbo would fail on a remapped car faster than it would on a non remapped car.
You know what would be nice. Instead of you attacking me be it personally as it was last time or calling my posts crap would be to offer a friendly explanation and point out where I'm wrong. I'm happy to work on my ignorance. You just seem to want to insult me. I'll remain cool about it if even just to annoy you .
The boost difference on a run of the mill turbo diesel remap is so small that is doesn't make any real-world reliability difference. If you can dig up a credible source of where the opposite is true, I'll happily eat my hat.
I've not personally attacked you, I've just derided you incorrect statements.
