- 5 Feb 2004
- South Shields, UK
You won't get the detail from 1024*768. How can you?? Its a significantly lower screen res from 1080p. And not even a widescreen resolution.
I see. But is the image quality not based on the resolution? The amount of pixels at 1920x1080 compared to 1024x768 is a big difference. Or what other factors come into it? Again sorry for the lack of knowledge from me, cant get me head around plasmas![]()
its down to what you display mostly
most of the reason why plasma image quality is regarded as better than LCD is when displaying standard resolution. Showing a SD picture at 1920 x 1080 stretches the picture much more and thus exposes more of the flaws
if you only expand it to fit on a 1024 x 768 screen, you dont stretch it as much and it hides much of the defencts of standard TV and thus looks better.
As for high definition content, most of the legally available HD content is gaming stuff be it console or PC. There are of course blu ray players as well, but the comment that LCD is better than plasma for gaming comes from the fact LCDs have much higher resolution and thus will look much better displaying a 1920 x 1080 PC image at that res, as opposed to downscaling it to fit 1024 x 768
But thats not to say plasma is hopless with HD content, there are more factors to IQ than just resolution. Theres the colour depth. Cheap LCDs will show the black background of starwars as grey for example. Great blacks has always been a plasma strong point. As has motion. Because plasmas dont have a refresh rate a as such, they handle motion better. However, due to the underlying nature of plasma, you often find your eyes can pick up on whats called "green fringing" as seen in this video
Plasma and LCD both have strenghts / weakness. Which you think is best is largely a personal choice![]()
