No V6, there's not likely to be one either
That sucks, there's an old type (style before present) one that I often see parked at my gym, it makes me wet every time i see it.
Car's looking great btw! And nice brakes too! Don't the Clio's come with Brembo brakes anyway?
It is reasonably flat underneath, not great though. To be honest I doubt it does anything at all but oh well it looks reasonably cool![]()
where did you take yours to be mapped? its something Ive been thinking about getting done
Where did you exhaust go?
Good effort on the cleaning front, how risky is it using a polisher?
Yeah they do come with brembos as standard, i've just got the drilled discs now because they look funky and was desperate for some new ones after Donington started to show it's real toll on the car about a week afterwards!
You are right about the flat spots too, they are very annoying, but I had my car remapped some time ago to give it a load more low down torque and it also got rid of these flat spots making it a LOT more pleasant to drive, it's still got nothing below 2000rpm but where before it had a big nasty spot between about 2.5 - 3k and another about 4.5k (I think) they have gone completely and revs very cleanly upto 7500rpm.
It is disappointing really that I had to spend an extra £300 to get it working as it should, but I'm glad I did.
