The New Cases Gallery
Thanks m8, you've been really helpful, & nice build by the way :)
Last question if I may? I see that the intake fan on the case bottom is screwed in? is it screwed in from underneath thru into the case just using normal fan screws? I only ask as my Cosmos has a fan there too but it cant be screwed in directly, it needs a fan casing!
Thanks again :)
yeah screwed in , though i cant remember if the screws went from inside the case to oustide or vice versa
Just noticed your edit! How'd you get those temps displayed like that? Are they part of the Vista side bar? :)
Does look better, but the p182 while being cramped was much more functional, secondly antec actualy respond to emails. Ive sent several to coolermaster asking about additional cooling for this pos and ive yet to get one response back.
"cooler" master my arse. :mad:
yup, ignored 4 emails (over 3 weeks) i sent to them re a new power button for a stacker..
less than useless
Here's a picture of mine since i got my EX-33B and tidied it. Will post another when I turn it off. All I can say is its damn hard to keep the cables tidy in a PC-7 when you have a 8800GTX and 4 hard drives in there.... :D
its my first ever modding/watercooling pc, Internals are matt black externals are Vauxhall Arden Blue
still a fair bit of work to do & more parts to come,
still waiting on a processor tho, yet to decide what tho yet
cooler scheme for the 2 loops will be Blue water with green coils & green water with blue coils
p.s. the white marks are polish as i gave it a polish after laquer had dried
already added the 2nd loop, case is in garage tho as my bedroom is currently being shuffled around a little over the next few days
Guardsmon reckon you can post a shot of your internals, would be interesting to see how you cable tidied, coz I'm in the same situation, 4hdds are a bitch to keep tidy
Naud
Hiper 120mm Chrome. They look great. They are rated as 20db with 60CFM and certainly keep it cool, but I've got the nvidia NB 40mm cooler on at the moment and there is certainly more than 30db of noise coming from it. At some point I'll take it off and make sure it is the NB cooler than is making the noise. Was just a little worried about the heat when I was pushing my Q6600 to 3.8 a while back.
Will try and get some pictures up this evening when I'm back at home.
