As title really; I'm looking for some good quality padding, probably shin pads, forearm pads, and knee/elbow pads.
Is there a lot of variation in quality, or is it all pretty much the same?
Thanks
Yup there does seem to be and it can vary between the products within the range too unfortunately.
I have:
Blitz footwear - the sole has split away slight so I now do it bare foot. Not tried breaking yet with bare feet - only with the shoes (I still wear them for that). Although these are my oldest bit if kit (~ 2 years).
Macho Rival shin guards - no problem
Blitz Storm foot guards - no problem
Blitz head guard - no problem
Bytomic 12oz gloves - ok, padding is still good although I have a slight feeling that the inside fabric has a bit of a hole. I don't use these on hard pads such as focus mits though, usually for sparring although sometimes for soft contact bag work.
Champion bag mits - a bit pants. They're ok from the glove but the velcro strap usually comes off in a few hits.. very annoying. Not used for sparring as I'd hurt myself and my sparring partner!
Loose velcro means whiplash to the pad holder! Not too good for your wrists either. We usually wear wraps anyway.
Groin protector - I think this is blitz too, no problems with it.
Game Guard Gum shield - clear one is fine and has set well, I have a solid green one and I've heard these aren't as good at setting (not done that yet).
We don't use knees or elbows nor spinning backfist. More korean, almost TKD like style. So I can't help with those bits of kit.
