New Mobo Arrived
Love the mobo box, as others have mentioned I wish that Asus took as much time and care with the layout of their boards.
im so envious and i think i need one of these in my life at the moment. hm if the price hadnt gone up...
the difference between the X48 LT and UT is the cooler, i believe one retailer confirmed this elsewhere.
That is an awesome looking motherboard!
Almost as nice as my good old LanParty UT NF4 SLI-D! I think I might get another DFI next time I upgrade!
Can't decide, this one or Asus Rampage Formula. DFI's bios options look a bit too complicated for me. Do keep us posted with this board though, a nice change Asus with all the silly names :cool:
My LT X48 is arriving monday, i'll do a follow up review with my Q6600 G0 but I'm rather green when it comes to intel, first intel system in over a decade. That said I'm sure it'll be fine :D
Very nice board mate ,going to get one myself soon:)
Just ordered a full set of Mips waterblocks for that motherboard to put on mine :)
Right, the review should be up at digital report later tonight and I will post a link when it's done. :D
If anyone wants to know where or how to obtain one of these DFI beasts, then please contact me on MSN ;)
Nice one Mike. :)
You need to make a comment on how bad the power and reset buttons are for your fingers. :D
Nice one Mike. :)
LOL Azza, you do realise that you dont have to open the case each time you want to turn your PC on dont'cha :p:D
& are you tryin to say I got fat fingers :eek::mad::p
DFI SPECS
DK = Performance
LT = Enthusiast
UT = Professional
In that order for price & performance, mind you i'm having trouble seeing what the differences between the LT & the UT versions... All I can see is an extra thermalright heatsink on the UT :p
Hello
The specifications for the DK, LT and UT range re: x48 are as follows:
x48 Lanpart UT T3R=
8-phase digital PWM
1600 FSB
Dual DDR3 1600
Jmicro JMB363 (2 SATAII+1 PATA)
8 Ports (6 from ICH10R+2 from JMB363)
12 Ports USB (6 Connector+ 6 Pin Header)
VIA VT6307 (2 IEEE1394 Ports)
PWM+NB+SB Heat-Pipe tHERMAL Solution
Bernstien Audio Card
X48 UT T2R
Same as above but using the DRR2 solution
X48 LT
8-phase digital PWM
1600 FSB
Dual DDR2 800
8 Ports (6 from ICH10R+ 2 from JMB363)
12 usb Ports Connector+ 6 Pin Header)
NB Tower Heat-Pipe SB Heatsink cOOLING soLUTION
X48DK-TRS
Dual DDR2 800
6 Ports (From ICH9R)
Jmicro JMB368 (1 PATA)
PWM +NB Heat-Pipe SB Heatsink Solution
Realtec Audio Card
cheers
Gilgamesh
DFI DK Guru for the UK
