- 23 Jan 2007
- Glasgow
Thanks m8, you've been really helpful, & nice build by the way
Last question if I may? I see that the intake fan on the case bottom is screwed in? is it screwed in from underneath thru into the case just using normal fan screws? I only ask as my Cosmos has a fan there too but it cant be screwed in directly, it needs a fan casing!
Thanks again![]()
yeah screwed in , though i cant remember if the screws went from inside the case to oustide or vice versa
