yes its a standard drive usually found in smarter looking laptops such as Toshiba Qosimo series and on Macs, there normally panasonic uj-8xx series, they are quiet delicate compared to a normal try loader as kids like to insert things into them, and the amount of mechanics inside is mind boggling, looking at a side on view of the 1330 would suggest its a strip down job to replace, which is fine under warranty but a bit trickier than your normal tray job
