Hi there
We have some truly unbelievable deals for you on BFG cards at the moment which coves the entire high-end range:-
BFG GeForce 9800 GX2 1024MB GDDR3 TV-Out/Dual DVI/HDMI (PCI-Express) - Retail
beautifully designed and engineered for extreme power, the bfg nvidia® geforce® 9800 gx2 1gb graphics card is the console within - a complete, high definition entertainment and gaming solution for the pc. with nvidia hybridpower™ technology and two on-board gpu's, the bfg nvidia® geforce® 9800 gx2 is bar-none the fastest graphics card available and up to 50% faster than geforce® 8800 ultra. when paired with an additional bfg nvidia® geforce® 9800 gx2-based graphics card and an nvidia nforce® 7 series motherboard, this quad nvidia sli® technology solution creates the most awe-inspiring, screaming fast gaming platform to date. be blown away by scorching frame rates, true-to-life extreme hd gaming, a picture-perfect hd dvd and blu-ray disc® movies with ultra-smooth playback.
- geforce 9800 gx2 core running at 600mhz
- shader clock speed of 1500mhz
- 1024mb gddr3 memory running at 2000mhz
- 512-bit memory interface
- 256 stream processors
- shader model 4.0
- texture fill rate: 76.8 billion/sec
- memory bandwidth: 128gb/s
- up to 50% faster than geforcer 8800 ultra
- display connectors: 2 dual-link dvi-i, hdmir out
- hdcp capable, hdmir capable
- designed for extreme hd gaming
- nvidia pure video technology
- dedicated video processors free the gpu shaders to run 3d applications
- dual dual-link dvi supports two 2560 x 1600 resolution displays
- hdcp enabled!!
- sli ready
- true high dynamic range rendering support – based on open exr technology
- world's first unified architecture supporting microsoft® directx® 10
- built for microsoft® windows® vista™
- lifetime manufacturer warranty (contact bfg representative on 001 866 234 3499 for warranty services)
- 24/7 email manufacturer support (http://www.bfgtech.com/tech_redux.html)
Note: This card is 295mm in length so make sure it fits in your case! Also the cards require PCI-E x16 slots, they will not function in a x8 slot so for SLi you need dual x16 mainboard. Finally 600W minimum for PSU and 700W+ is recommended. Also make sure your PSU has true 8 pin PCI-Express connector rather than a 6+2 pin connector.
Price: £309.99+VAT (£364.24 Inc. VAT)
buy now!!
bfg geforce 9800 gtx 512mb gddr3 tv-out/dual dvi (pci-express) - retail
the bfg nvidia® geforce® 9800 gtx 512mb graphics card raises the performance bar by enabling full-throttle lifelike game play at intense resolutions while providing optimal power management with hybridpower™ technology. the purevideo® hd engine delivers unmatched video and movie quality with spectacular picture clarity featuring scene-optimized color and contrast enhancement. and when coupled with nforce® sli®-ready motherboards, provides amplified performance up to 2x in a dual sli configuration and up to 2.8x in 3-way sli* mode. packing more performance at an exceptional value, the bfg nvidia® geforce® 9800 gtx 512mb graphics card offers extreme hd gaming and a first-class entertainment experience.
- geforce 9800 gtx core running at 675mhz
- shader clock speed of 1688mhz
- 512mb gddr3 memory running at 2200mhz
- 256-bit memory interface
- 128 stream processors
- shader model 4.0
- full-throttle gaming at extreme hd resolutions and support for 3-way nvidiar slir mode
- full microsoftr directxr 10, shader model 4.0 and pci expressr 2.0 support
- hdcp enabled!!
- sli ready – upto 2x the performance of a single gpu (available on with future driver release)
- free bfg t-shirt, teflon stick pads and stickers
Note: This card is 275mm in length so make sure it fits in your case! Also the cards require PCI-E x16 slots, they will not function in a x8 slot so for SLi you need dual x16 mainboard. Finally 500W minimum for PSU and 600W+ is recommended.
Price: £174.99+VAT (£205.61 inc VAT)
buy now!
bfg geforce 9600 gt oc 512mb gddr3 tv-out/dual dvi (pci-express) - retail
the bfg nvidia® geforce® 9600 gt oc™ 512mb graphics card offers a powerfully immersive entertainment experience designed for high-definition gaming and video playback. play the hottest microsoft® directx® 10 games with awesome speed and watch the latest hd dvd and blu-ray disc® movies with brilliant clarity, powered by the revolutionary purevideo® hd engine. couple two bfg nvidia® geforce® 9600 gt oc™ graphics cards together with an nvidia nforce® motherboard for an optimal graphics platform, giving you the gaming horsepower to handle the most demanding games with nvidia sli® technology. with the bfg nvidia® geforce® 9600 gt oc™, amazing graphics performance is now within your reach.
- geforce 9600 gt core running at 675mhz
- shader clock speed of 1700mhz
- 512mb gddr3 memory running at 1800mhz
- 64 stream processors
- shader model 4.0
- memory bandwidth: 57.6gb/s
- hdcp enabled!!
Price: £89.99+VAT (£105.74 inc VAT)
buy now!
bfg geforce 8800 gts oc 512mb gddr3 hdtv/dual dvi (pci-express) - retail
this isn’t your daddy’s geforce 8800 gts. featuring a full 128 stream processors, each individually clocked at a blazing fast 1.674ghz, and an impressive 512mb frame buffer with 256-bit interface, the bfg nvidia® geforce® 8800 gts oc™ 512mb graphics card delivers top-of-the-line performance that enthusiast’s have been demanding at a price that will have to be seen to be believed. ultra-realistic smoke, rain, explosions, lighting, terrain deformation and motion blur enable jealousy-inducing, lightning-fast gameplay in the hottest games, including crysis, hellgate: london, call of duty 4, and gears of war. with full support for pci express 2.0 and featuring second generation nvidia purevideo™ hd engine, the sli™-ready bfg nvidia geforce 8800 gts oc™ graphics card has the feature set to match the amazing performance.
- nvidia® geforce® 8800 gts core running at 675mhz (g92 low power consumption edition)
- pci express® 2.0
- 512mb gddr3 high speed memory running at 1940mhz
- shader clock speed of 1674mhz
- stream processors: 128
- texture fill rate: 41.6 billion/sec.
- memory bandwidth: 62.1gb/sec.
- shader model: 4.0
- api support: microsoft® directx® 10 and lower, opengl® 2.0 and lower for microsoft windows®
- connectors: (2) dual-link dvi-i, hdtv + tv out
- ramdacs: dual 400mhz
- hdcp capable: yes*
Price: £139.99+VAT (£164.49 inc VAT)
buy now!
bfg geforce 8800 gt oc2 512mb gddr3 hdtv/dual dvi (pci-express) - retail
your search for the perfect graphics card is over. the ideal combination of power, performance, and price, the bfg nvidia® geforce® 8800 gt oc™ graphics card offers 112 stream processors, a 512mb 256-bit frame buffer, standard-setting geforce 8 series features and, a strikingly immersive directx 10 gaming experience. ultra-realistic smoke, rain, explosions, lighting, terrain deformation and motion blur enable jealousy-inducing, lightning-fast gameplay in the hottest games, including crysis, hellgate: london, call of duty 4, and gears of war. with full support for pci express 2.0 and featuring second generation nvidia purevideo™ hd engine, the sli™-ready bfg nvidia geforce 8800 gt oc graphics card was worth the wait.
- geforce 8800 gt core running at 675mhz
- 512mb gddr3 memory running at 1950mhz
- 112 stream processors
- shader model 4.0
- hdcp enabled!!
Price: £119.99+VAT (£140.99 inc VAT)
buy now!!
bfg geforce 8800 gt oc 512mb gddr3 hdtv/dual dvi (pci-express) - retail
- geforce 8800 gt core running at 625mhz
- shader clock speed of 1566mhz
- shader model 4.0
- hdcp enabled!!
Price: £107.99+VAT (£126.89 inc VAT)
BUY NOW!
I think you will all agree these are incredible deals especially considering they are BFG cards which come with lifetime warranty and most are overclocked out of the box. So guess what? GET YOUR WALLETS OUT!
- shader model 4.0
- hdcp enabled!!
- sli ready
buy now!!
- shader model 4.0
- hdcp enabled!!
buy now!
- shader model 4.0
- hdcp enabled!!
buy now!
- pci express® 2.0
- shader model: 4.0
buy now!
- shader model 4.0
- hdcp enabled!!
buy now!!
- shader model 4.0
- hdcp enabled!!
BUY NOW!
