Q6600 FPO# L740A746
I dont have that chip or your cooling but you should be looking at around 38°C at idle and 61°C at full load on good aircooling with that voltage and clock. hows that sound?
Mine is 378x9 @ 1.465v.
Temps are between 34C-40C idle (room temp makes a huge difference), was hot last night, so hit 40C.
I'm putting a lot of volts through that, so if anyone gets hotter than me at same clock, they need to sort cooling out.
Mines not that far different from yours, although I've got a little more voltage but same clock (3.4) and temps are slightly lower. What cooler have you got on your CPU?
I wouldn't run it over 70degC.
Isn't your system partialy water cooled though? That will bring the case temp down.
