ratio = number1 / number2
Code:ratio = number1 / number2![]()
It is, but it shouldn't be! Far too much processing power wasted on modern computers.It is that easy.
private const double P = 0.000000000000001;
public double GetRatio(double a, double b)
return GetRatio(a, b, 1, 1);
private double GetRatio(double a, double b, double c, double d)
if (b * c < a)
while (b * c < a)
c += d;
else if (b * c > a)
while (b * c > a)
c -= d;
return (b * c == a || d < P) ? c : GetRatio(a, b, c, d / 10);
Cheers, wouldn't take too much work to hook it upto a progress bar either! Of course you'd have to put the thread to sleep on each recursion or you'd hardly have time to watch it.I like it. Very enterprise-y.....
Yes, I could also run a Web 2.14 (I upgraded) AJAX Enabled website to provide users with a fast access method of getting ratios rather than having to rely on their other systems.Perhaps you caould turn it into a webservice? That would be, like, totally awesome.
I'll get the server ordered and look into the best ways of advertising the new service we're offering.
Mick.
Function GetRatio(ByVal a As Integer, ByVal b As Integer) As String
Dim hcf As Integer = 1
For i As Integer = hcf To Math.Min(a, b)
If a Mod i = 0 And b Mod i = 0 Then
hcf = i
End If
Next
Return String.Format("{0}:{1}", a / hcf, b / hcf)
End Function
