- 12 Feb 2006
- Surrey
is there an add on for ff2 that will allow you to lock and mark them cookies as safe, so that they never get deleted when deleting all cookies? i ask as every now and then i delete my cookies but as there is a lot i like to keep such as for this forum, i end up having to select each one at a time which gets tedious very quick
also i have asked this before but the suggested add on turned out to not be what i am after, bascially looking for an add on that allows you to split the tabs up and view 2/3/4/5 at the same time, like notepad++ if you have ever used it or mathon browser . I was tried splitview but this isn't that great and doesn't give the same as just having 2/3 tabs open and viewed at same time.
thanks
thanks
