best free software for making an imagie of my computer
5 Jun 2005
Southampton
had loads of trouble doing a clean install with vista, and at the mo i have xp all set up and working, i need an imagie so i can frig about with vista, but have something simple to revert back to instead of having to do all the updates and setup everything.
what would your recomend, needs to be simple :p and free:)
You could try: http://www.runtime.org/driveimage-xml.htm
Another good thing is that this can also be integrated into a copy of BartPE. I can get the guide if you wish.
