Permabanned
- 15 Jan 2006
This is a continutation of another of my threads. Thought I'd make a new one because the problem has changed since the original thread and it'll just be a lot less confusing.
Here is the sytstem I've just built.
- Antec NSK 4480 Mini Tower Case (Silver) - 380W Earth Watts PSU
- Intel Core 2 Duo E2200 "LGA775 Conroe" 2.20GHz
- Samsung SH-S203D 20x DVD±RW SATA Dual Layer ReWriter
- Gigabyte GA-73PVM-S2H GeForce 7100 Micro-ATX (Socket 775) PCI-Express DDR2 Motherboard
- Samsung SpinPoint T 500GB SATA-II 16MB Cache
- OCZ 2GB (2x1GB) PC2-6400C4 Dual Channel Platinum Revision 2 XTC Series DDR2
When I boot up the computer and start to install Windows XP it gets to the first part where it says 'Setup is loading files' and after that it says 'Setup is loading Windows' and then the screen goes blue and I get that message that tells you the computer has been shut down to prevent damage. The error code is - 0x0000007b (0xf78d2524, 0xc0000034, 0x00000000, 0x00000000
The error code may not have been the same, but I had something very similar to this happen with my last build. The difference being that the crashes would come at random times, but mostly during gaming. In this case the crash comes at exactly the same part each time, just as 'Setup is loading Windows'. With my last build the problem was my MSI motherboard didn't like running my GeIL RAM in dual channel. Obviously with this in mind my first thought was to try each stick of RAM, one at a time. Unfortunately no luck, although the first time I did it the error code did change slightly - 0x0000007b (0xf79e3524, 0xc0000034, 0x00000000, 0x00000000
I've tried running a scan on my hard drive and no errors were found. I also ran memtest through twice and again no errors were found. I've also, of course, looked inside my PC to check all connections are in firmly and nothing has come loose.
Is my PSU definitely up to the job? When I posted round on other forums asking for advice with my previous problem a few of them pointed to my PSU being 'inadequate'. Slightly dubious of that though because I've had people adamant my PSU is the problem when I've had PC troubles before and it's turned out to be nothing to do with the PSU. Also the spec I built was recommended to me from an established member on here.
Really stumped as to what could be the problem. Anyone have any ideas?
