Piercing a beer can and downing it...
No technical term afaik. It's carp and you should just down it from the normal aperture/ from a glass. Much quicker that way ;)
It's a shotgun.
Make a hole near the base of tha can and apply suction, tilt back head with mouth attached to aperture, apply serious suction and open ring pull maintaining suction. The beer should then rush down the throat at a rate of knots.
At least, that's how we did it when I was young and silly.
It's a shotgun.
At least, that's how we did it last night.
:D:D
Anybody know the technical term? And how it's done properly?
Pierce the bottom edge of the can with something sharp - a Biro sometimes works if you can't find anything else, then open the can of beer normally on the top - this will send the beer rushing downwards into your mouth as the air needed to fill the emptying space is down on the top.
Just relax your neck / throat if you know how to, let the drink roll down:)
I used to do the alternative with bottles.
Stick a straw in the bottle, bend the neck over away from your mouth and just suck it through the bottle as normal, the straw lets air into the bottom of the bottle.
Remember downing bottles of alcopop at something like 2.2 seconds lol
I remember doing this with 3 bottles of wine in less than a minute, then i dont remember anything after that...
It's a shotgun.
Can just about remember a friend getting me to do this with 3 cans of beer and a glass of brandy afterwards. I was 14 :o
