Best antivirus and firewall
5 Jul 2005
Edinburgh
Whats peoples opinions on this.
Use to use nod32 and commodo but got rid of commodo due to it causing BSOD's in winxp but apparently that has been fixed now - anyone confirm this or is it best to use the new nod32 with firewall as well?
Not sure about Comodo, but for Antivirus, if you're wanting free then i would recommend Avast 4.8, which now includes Antispyware and Antirootkits too. Very efficient with resources too, I use Windows Firewall, but I did briefly use Comodo a bit since and it worked flawlessly!
I've never bothered with Windows Firewall or any Firewall, Just rely on the routers firewall. Never had a problem.
As for Antivirus I use Avast, it does everything I need and its free.
For XP I use Sygate Personal Firewall. For Vista I just use Vistas built in one.
Avast! for me, been using it for years. Great product.
Have not used a firewall for over a year now, I just used the built in windows one and my routers own firewall. Avast is a very good AV for free, but if you have Nod 32 already then stick with that :).
Been using Comodo +Defense (freeware) for a while now. Its Application-Monitor does nag a lot but then I found a simple right-click on its icon in the system tray and you can disable the warnings (which resemble Vistas UAC). The firewall hardly nags and when you first install - it quickly goes through its learning process. I guess it comes with a database of known safe programs. You can set its mode though if you want more agressive control. A great freeware offering I think.
I use AVG for the antivirus side of things. Its interface is clunky with Win 98-style windows popping up all over the place. They need to tie it all in - like Avira does. But its given stellar service.
I've been using Nod32 for a good while now, and recently (~1 month ago) have been using Comodo Firewall with it. I run Windows XP Home (SP3) and have had no problems at all. :)
