Rather embarasing this.. just looking for any advice really.
Like a numptey last night when I was doing a couple of checks, I took the Oil Cap off, which I neglected to put back in.. and only realising this afternoon when I went to go check my VIN plate for a the Ford Colour Code thread on here.
Now it made a bit of mess, went down to my local Halfrauds and got some Gunk, had a spray and got most of the visable stuff up.. the car was smoking a fair bit the first time I took it back out without.. but now i've used the stuff, the smoke seems to of cleared up.
Daft thing is.. i found it on the floor where my car was after shooting over to my local Ford dealer to get a replacement.. they didn't have any.. but at least I found it.
Now is there anything I should really be worried about.. the smoke seems to of disipated but I can't really check this till tomorrow morning on my journey to work... there was a small wire at the rear of the bay that seemed to get some on it (Small loom just to the right of the Power Steering Fluid Reseviour)
Also the car seemed to be idleing a bit higher.. am I best just asking my dealer to check it over when it goes in Thursday?
Any advice appriciated.
Thanks
Thanks
