CC Tubes, pink not red. Can I?
23 Jan 2007
Glasgow
Guys
I bought some cold cathode tubes for the inside of my new case (Cosmos S), Unfortunately they look more pink than red. Is there any kind of film or plastic sheeting i could get to make them more.. well red?
cheers
you could try using lighting gels they tend ti come in quite large sheets but can easily b cut to size. not sure how the styling woud look though cos it just like wrapping plastic round them
most good photography stores should stock them
Ah ok thanks, I had a rough idea of what i was looking for but had no idea what it was called. I'll pop into town and have a look for lighting gel then.
cheers
You could also trya translucent red paint, I was gonna do the same with some red cathodes of my own, but I've decided to not use cathodes anymore after seeing the damage a cathode inverter had done one time :eek:. I'm using LEDs only now (currently only LED fans), I've built a blue LED array light that's pretty bright, but I've yet to put it in my case, works out cheaper than cathodes too, if anyone's interested I could post some pics up of it later. :)
Im also looking for a darker red lighting solution but have not yet found any that do not look pink. I would like to find some red neon string but the only stuff I have found so far is the Optx® By StreetGlow stuff which Im not sure I can actually use in a computer.
Google " Mutant Mods Electro - Luminescent Wire "
In loads of colours , i even managed to get Purple.
Mark
