I do use the brakes quite hard tbh, think I've warped one of my new EBC discs too.
Truck wash.
Aggitate it with a dustpan brush, Leave it for 5 mins, hose it down, JD.
Agreed, otherwise known as "TFR" - Traffic Film remover.
Just the ticket.
Viro-Sol is a strong alkali. Even diluted to 1%, it’s capable of corroding and staining alloy wheels. It’s designed as a toilet cleaner, but some years ago a guy tried marketing it as a wheel cleaner, but many discovered how it can corrode/stain wheels.Virosol , job done
I have tried dozens and this is better than everything else I have tried and non corrosive
I put TFR on my FLT at work the other day, probably did a 4:1 mix, and the colour (orange) washed off in places, good job its due for a paint soon!
try a household steamer.So i've neglected my wheels over the winter months and theres a big build up of brake dust on the fronts which even wonder wheels won't touch, anything stronger i can try? Would 'autoglym intensive tar remover be of any use?
Ta![]()
you have any info on this as it goes against everything I have seen but if it is true I will stop using it
Didn't you have a couple of alloys that started corroding?, might be something to do with it.
wounder wheels yep might have to use a scrubbing brush of some kind but will still work
Wonder Wheels will sort that Wez.
Ta![]()
