Mobo not holding OC
6 Dec 2007
Hey, basically, I screwed up an overclock om my GA-P35C-DS3R, and had to remove the BIOS battery to reset it. Now, having re-entered my OC settings, I select F10 to apply them, but when I check CPU-Z, it reports CPU at stock (e2180) and RAM running underclocked. :confused: If I had a beard, I'd be scratching it...
Up the MCH and FSB voltages by 0.1? I had that problem when I first started clocking this board, that that solved it
Naud
Reflashed to the F10 BIOS, Speedstep is off, and I have always had the voltages upped by 0.2, and its worked fine. The computer will work, it just won't overclock. Thanks, and any other plans?
Not on the basis that it won't overclock, because I know I can't do that, I meant on the basis of a dodgy BIOS or something (which I'm assuming it to be because, despite a reflash, it won't hold any settings I give it).
