Hi all,
I've just put together my new build as follows:
ASUS P5K 775 motherboard
E6600 2.4Ghz
2 * 1Gb 1066Mhz Crucial paired ram
Sapphire 2600XT Silent.
160Gb WD SATA drive
An older PATA Sony DRU500A DVD+/-RW
Here's the problem:
I attach the PATA Sony drive to the external chipset supporting 1 PATA channel (JMicron I believe) and the SATA HDD to the onboard headers, both drives get picked up by their respective controllers and the Vista CD seems to start perfectly.
This is when the issues start, once Vista has loaded it's Install GUI it seems to hang for quite sometime with just a Vista desktop background and a mouse cursor (sometimes without - i think that depends if I have my mouse connected) with no CD activity. This lasts about 4 - 5 minutes.
The then first screen appears asking which language and then "Start Installation" button. Once I click that, again, 4-5 minutes with little or no activity, then the CD Key entry screen.
I enter that and click next, again, 4-5 minutes until it comes to "Copying files (0%)..." which seems to get "checked off" (ie done) before the CD has even spun up and then I get an error message saying a file cannot be read.
I have tried disabling ALL non-critical bios stuff, I've moved my HDD to the same controller as the CD drive (it has a SATA connector here as well, for RAID I believe), I've checked the disk in another drive, it reads fine.
I've tried the RAM in all combinations, 1 stick only etc.
I connected my really ancient 40Gb PATA drive with Vista preloaded from an old computer and that booted fine (after Vista had sorted out the hardware changes). Can I leverage this to install Vista on my new drive?
I'm really stuck as to what to do next so any advice would be grand. DIMM voltage? What am I missing?
E6600 2.4Ghz
160Gb WD SATA drive
Here's the problem:
