Another quote from Cadwell - http://photography-on-the.net/forum/showpost.php?p=4264234&postcount=8
His website : http://www.racepicsuk.com/
Have a look in my lens list (it's in the signature) and then I will tell you that I own two lenses that are optically better than my 120-300mm. One is the EF 135L and the other is the EF 600L. Even then there isn't a lot in it. I will also tell you with confidence that the 120-300mm is the fastest focusing zoom lens I own.
Im more likely to get the 300mm + 1.4...
