- 12 Apr 2004
- Somewhere
str:
The OEM licence is designed for system builders, where it is assumed that no major system upgrades will take place after the first installation of Windows. Therefore, there is no necessity for the licence to be transferable to a new system (i.e. an upgraded one). This is the reason that it is cheaper.
If you don't like these licence's terms, then don't bloody well get an OEM licence; it's not designed for consumers like you, so you have no right to complain about it! The mere fact that you can buy it has no bearing on the fact that it's not designed to cater for you. There is a licence that does what you want, and it's called a Retail licence. If you want to install on different systems, then get that one instead. It's a no-brainer.
By your reasoning, if Microsoft were to start using another, even more restrictive licence, which could only be used on one system one time (no reinstalls allowed), then you, as a consumer, should be morally entitled to use this licence as many times as you want on as many different systems?
You're essentially saying that it's immoral for Microsoft not to allow you to use a licence outside its terms, which makes no sense whatsoever.
I don't get it
I don't get it
