Bad luck Easyrider
My Zotec went further
Hence why I got a better score in 06.
ouch
Sold mine 2 weeks later
Bad luck Easyrider
Cool your card better Azza and watch you Shader clock fly! pretty much key to a fast g92 gfx card.
My 8800GTS is pretty crappy so far, memory only overclocks to 1058, core and shader speed of just 756/1890 is causing crashes, might send it back.
i would like to know what reason you will give when u rma your my graphics doesn't overclock well![]()
Is it possible to bios flash the 8800GTS to give more GPU voltage?
I remember way back when that it was possible to eek out annother 0.05V on the GT's with a bios flash.
Any amount of ATI Tool artifacts should instantly make you slow down the clocks - run it through some Crysis and Vantage loops and look for artifacts. Ati Tool is usually perfectly fine for me, but i have had cases where i had artifacts in Vantage and where Folding@Home crashed even though it was stable in ATI ToolHi
Going to use rivatuner & ATI tool to see how far i can push it (my 8800gts g92), but still run games stable. Not had any experience with ATI tool, so just wondering how results translate to actual gameplay stability, and if a certain number of ati tool artifacts can still mean the clock will be ok for games?.
joe
