- 12 May 2005
I know that most GPU's are standard design, but never had a PNY before. Are they a good brand ? like will it die in 2 months for example
Thanks
Thanks
Thanks![]()
yes they ship with a special bios that kills the card after 90 days.
If it dies, RMA it! Or, get a 9600 GT for almost £20 less.
Question is, how good is PNY's RMA service?
One last question
How many power connectors does the GT have ? I assume 1 ?
HI there
Well you can RMA to OcUK anyway if you don't want to use PNY's service but they are actually very good. PNY are a very large NVIDIA partner who have been established for several years, they used to be and still are well know for their Quadro range of cards.
So they are a very high ranked partner of NVIDIA's and they know how to look after customers, they also manufacturer memory too so they are a very big player who've been around for a very long time.![]()
Will this cack all over my X1950 and is it worth the jump? Please say yes.![]()
Hi, from anyone who has bought this card.
Can you tell me if this is a single slot graphics card cause I've had to return a few cards because it had dual-slot cooling
Many thanks
Had one delivered today,and yep it's a single slot just like the reference card.
Is it noisy or does it have the later, larger sized fan ?
