Anyone using Lian-Li PC-B25B
Hi - as title. I need a new case to fit longer graphics cards & the water cooling option is a +. Thanks
I have one and I doubt you will get a graphics card that is longer than the width of a motherboard in there.
Dang that literally kills it for me then was considering grabbing that case....
Its important to have plenty space in front of the card with good air going over it imo....
Looks like back to the massive Lian Li cases then :)
I managed to shift all my stuff from, a V2000 to one of these and managed 6 hard drives using 1 adaptor but there would be no room for one of the big graphics cards with room for cooling. Its a well built case though, one of the nicest ones I have had and very quiet (the reason I got it).
Can I ask were u able to remove the hdd cage completly?
Surely this would allow tons more space for long graphic cards....
I was still considering this case and simply mounting my hdds in the top 5.25 bays with silent hdd boxes.
Yes it will come out completely. I took mine out to turn it round. You would have room then. I noticed in other threads your comments about aluminium resonating , that's something I have not come accross with this case due to the way the sides are constructed. The door is also a solid fit the way the catch holds it when shut. I am quite anal when it comes to noise and the PC I have in this case is very quiet even with 6 hard drives.
Thx good to know, so far this is one of my next pickings for case wise :)
Has the looks, been designed for silence in mind....
I proberly would go overboard and jam it with very silent 5v 120mm fans and even japanese gup silent boxes not to mention accoustic foaming :)
Good to know theres no resonating also.
Im only a silent freak cos I gotta sleep 1 meter away from my pc.
The double skin on the sides works well to stop resonating. I had some Noctua fans from my V2000 and love the silence.
Sounding better :)
I saved my noctunas from my last pc... quickly replaced them with generic 120mm fans lol not like the customers gonna notice any difference ;)
