Weekend Special - PNY GeForce 8800 GTS 512MB GDDR3 @ £129.99+VAT (£152.74 Inc. VAT!!)
OcUK Staff
17 Oct 2002
OcUK HQ
HI there
We have another amazing weekend special for you guys, this time on an 8800 GTS 512MB GDDR3:-
PNY GeForce 8800 GTS 512MB GDDR3 HDTV/Dual DVI (PCI-Express) - Retail
The latest graphics card from NVIDIA is a new re-vamped 8800 GTS with 512MB of GDDR3 memory and more shader pipelines along with increased clock speeds to a huge performance boost. The G92 core is the first chip nVidia has produced using a 65nm manufacturing process which allows the kernal to run at higher frequencies with reduced heat output. Along with 128 stream processors this card has enormous potential with performance close and sometimes matching the GTX in benchmarks.
- NVIDIA® GeForce® 8800 GTS Core running at 650MHz (G92 Low Power Consumption Edition)
- PCI Express® 2.0
- 512MB GDDR3 High Speed Memory running at 1940MHz
- Shader Clock Speed of 1625MHz
- Stream Processors: 128
- Texture Fill Rate: 41.6 Billion/sec.
- Memory Bandwidth: 62.1GB/sec.
- Shader Model: 4.0
- API Support: Microsoft® DirectX® 10 and lower, OpenGL® 2.0 and lower for Microsoft Windows®
- Connectors: (2) Dual-Link DVI-I, HDTV + TV Out
- RAMDACs: Dual 400MHz
- HDCP Capable: Yes*
- 2yr Warranty with PNY.
Price: £129.99+VAT (£152.74 inc VAT)
BUY NOW!
Get your wallets out! :D :D :D
If it carries on like this, I'm getting the C64 out of the loft and sticking with that.
With the great sounds of the fax machine when a game is loading. No thanks :p.
@ Blackhawk47. Yes, that PSU will be fine :).
