Same card different box
You could say that about the GTS but not so much the GT. Fair enough the difference is negligible between them both but the GTX has what 16 more SP's than the GT. So technically you're wrong
Have to say crysis and WIC are the only games I cant play at 1920x1200 with my GT
Only game that it really doesn't handle at 1920x is crysis - there may be other games I don't play...
COD4 1920x with all settings maxed rarely drops to 40fps (start of some missions with large views over cities, etc.) and is mostly around 80-120 even in firefights.
Oblivion, ETQW, BioShock and several other fairly recent games that I've played all run acceptably on an OC'd 8800GT at 1920x with max settings and 4x FSAA - tho admittedly its much better at resolutions below 1680x.
Read his post..
I'm not spelling it out.
. It's called "nija" apparently
.Best of all we're still waiting for Easy to explain himself. J.D can you provide any insight into it?
.I went for the 9800GTX as I was desperate for something new to play with, my o/c BFG 8800GT OC could handle pretty much anything apart from crysis at my gaming res of 1920x1200.
Big disapointment was the mem wouldnt go above the stock 2.2ghz, core I got up to 790Mhz.
My 8800GT was clocked as per sig, for a single slot cooler I think I got pretty lucky with this one.
3dmark06 went from 14000 to 14800
Crysis (1280x1024 high 64bit dx9) went from 44.37 to 53.74
World in conflict (1920x1200) went from 22/11/42 to 23/11/47
In short I was very disapointed, I guess I have been spoilt by the good overclock I got out of my GT, that coupled with the very poor ram overclock of the 9800gtx
.Aye I see what you are both saying. It's playable and gives decent FPS but sometimes could do with a little more grunt from what you say Rroff. So it's usable to a good degree @ 1920x1200+ but if you wanted a better experience you'd want a GTX for that resolution. I think if I got a GT or GTS at my resolutions I would feel it a little due to using the GTX overclocked at high resolutions with AA,AF on. If I started with the GT then I might not be as fussy. If you feel the burn sometimes Rroff @ 1920x1200+ even if it's minimal then I'd most likely feel it too.
I think I covered this, I wasnt expecting night and day and I was really just upgrading for the sake of itOP what did you expect?
8800 cuts through
and upgrading from 8800 GT to 9800 GTX means you have money to waste or just after the upgrade
Sorry I cant let this go in case anyone is thinking of buying a GT and games at 1920x1200, it really does handle all games without a problem except crysis and wic (which I think may be more cpu limited as the upgrade to 9800gtx gave practically no improvement)
I run fraps so I know my frame rates at this res.
.Well, both you and Rroff have different views and it's opinionated. What you may deem as acceptable might not be the same for others.
Of course, and applies to all of us.
What I deem acceptable is typically 60fps dropping to 30fps in heavy firefights.
I get this with TF2 at 1920x1200 8xMSAA, with Jericho I also get this but cant enable FSAA, with COD4 I get this with FSAA
Managed to squeeze 800/2350/1900 out of my GTX now, some reason it has just decided to day that it'll be artifact free at 800 core, whereas Thur/Fri it wouldn't go over 765... how odd...![]()
then clearly your problem with artifacts is not down to the core speed. Far more likely it was the memory or shader at its limit as nearly every gtx clock unless really u/l would hit 765 no problems going by other ppl's o/c scores and online reviews.On taking your word you do actually own a 9800gtxthen clearly your problem with artifacts is not down to the core speed. Far more likely it was the memory or shader at its limit as nearly every gtx clock unless really u/l would hit 765 no problems going by other ppl's o/c scores and online reviews.
Mine personally maxes out at 818 on air.
