Striker Extreme - FINALLY A DECENT BIOS :)
15 Feb 2006
Staffordshire
http://www.keepandshare.com/doc/view.php?id=453538&da=y
Version 1504
Not on Asus website yet!
1600 (400MHZ) FSB hole now sorted
Big over clocks near to stock voltage
MUCH more stable:
:D
just updated mine aswell to this 1.not tried to push my cpu anymore yet but will try later.gonna try for 3.6-3.8 could not get this on my old bios.but seems to be stable on my old settings.i had the hole from 1600 to 1800.what sb and nb volts are u using
Go for it mate :D Piece of cake compared to the shower of crap that was all previous BIOS (1303 accepted).
Post here if u get stuck - I'll check back later.
Try 3.6 (1600 X 9) at stock voltage for CPU vcore but:
Set CPU VTT to 1.5V
Set NB to 1.5V
All others at auto
cant get it to post past 3.4 even with 1.5v through it.Thats 1700x8.using a 6750chip.max multi is 8.but i would have thought i could get more out of this.so at present i have it at 3.4 with 1.4v.maybe i should just be happy with that.maybe the bios just helps the quad users.May be i need to get quad
With that FSB you need more through the 1.2HT V.
Try as I suggested above mate:
1600 X 9
*EDIT* Sorry dude, only skim read that - tou are on a different CPU to me.
Try increasing 1.2HT Voltage to 1.45
Howdy,
Looks like you're getting some decent speed out of this puppy now...
Me, i'm currently speccing out a decent (big) case, a water setup and something to replace my 8800 320mb GTS then i'll be back in the fray...(mibbles a 8800GTS/ULTRA or 9800GTX) I dunno which yet but it's safe to say I need to do some overtime at work...
Mine runs fine @ 3.6GHz but i'm not happy with the temps.
these are my settings, and i'll admit now, these were taken from elswhere on the forums:
AI Tuning: Manual
Nvidia GPU Ex: Disabled
FSB - Memory Clock Mode: Unlinked
FSB : Mhz:1600
MEM (DDR), Mhz: 800
CPU Multiplier: 9
Vcore Voltage: AUTO
Memory Voltage: 2.1v
1.2v HT Voltage: AUTO
NB Core Voltage: 1.45v
SB Core Voltage: AUTO
CPU VTT Voltage: AUTO
DDRII Controller Ref Voltage: AUTO
DDRII Channel A Ref Voltage: AUTO
DDRII Channel B Ref Voltage: AUTO
tCL (CAS Latency): 5
tRCD: 5
tRP: 5
tRAS: 18
Command Per Clock (CMD): 2 clock (2T)
Advance Memory Settings
tRRD: AUTO
tRC: AUTO
tWR: AUTO
tWTR: AUTO
tREF: AUTO
Async Latency: AUTO
CPU Spread Spectrum: Disabled
PCIE Spread Spectrum: Disabled
MCP PCIE Spread Spectrum: Disabled
SATA Spread Spectrum: Disabled
LDT Spread Spectrum: Disabled
CPU Internal Thermal Control: Disabled
Limit CPUID MaxVal: Disabled
Enhanced C1 (C1E): Disabled
Execute Disable Bit: Disabled
Virtualization Technology: Disabled
Enhanced Intel Speedstep Tech: Disabled
LDT Frequency: 5x
PCIEX16_1 Frequency (Mhz):set to 101
PCIEX16_2 Frequency (Mhz):set to 101
PCIEX16_3 Frequency (Mhz):set to 101
SPP<->MCP Ref Clock, Mhz: 200
Q6600
2Gb Geil RAM
BFG 8800 320GTS
WD Raptor 74Gb
Vista 64bit Ultimate
Laters,
Muddy.
sorry to jump in but is this worth purchasing?
**B Grade** Asus Striker Extreme nForce 680 (Socket 775) PCI-Express DDR2 Motherboard
£93.99??
