Hmm bios i have a go at that but i am not confident on really touching that as of yet
You're confident on putting together the fastest pc possible, but you're afraid of flashing the mobo ?
WTF
Graphics - 3 x 9800 GTX 512 MB Ram
Yet you only got 4gb ram?
fail![]()
Are you being sarcastic? Why would he need more.
Hmmm do 3 of those cards run crysis on very high with 35 + fps ?
a 2.85Ghz overclock seems rather lowly for a newb overclocker, nevermind someone with tri-sli!
Which graphics drivers are you using?
You tried stroking it? Normally works for e-peens!
First of all i may be wrong, but with 3 graphics cards, windows will use 1.5gb out of 4gb due to 3x512mb.
So take out 2 of them.
Get all the correct drivers installed.
3 SLi is not very good anyway. Bearly any performance increase compared to 2.
bigger disappointment when i run - Frontline - Fuel for War, Turning point and even Hour of victory.
