Hey Guys, got my machine all up and running, but had to use an IDE DVDROM and not the Sony NEC Optiarc AD-7200S 20x DVD RW SATA Dual Layer RW, it’s brand new with all my stuff from OCUK,
I can’t seem to get the thing to work corretly, it takes an age to read a disk and after a whle it will come up with ‘not responding’ this is the same with data or audio too. Sometimes an audio CD will play and then it cuts out after 10 seconds or so. I can't install any programs using it.
I don’t have another SATA drive to test, but have concluded it’s not the cable or the SATA port on the motherboard. As i have swapped the HD around and that works in either port with either cable. My shuttle only has two SATA ports 'SATA 1' and 'SATA 2' as labeled on the motherboard, i presume 'SATA 1' is the default for the HD?
just wondering if there might be any bios settings i’m missing ? as the bios does pick it up. Gonna try and borrow a SATA cdrom of someone and test, but would appreciate any ideas or random guess’s knowing my luck it’s a duff drive!
but what happens if i send it back and it's not?
