Thanks guys.....
OK, so far I've managed a stable overclock at 3.2ghz with my Tuniq Tower's fan almost turned off! (temps for all four cores according to Everest are: 32, 30, 30, 32. With the 'CPU' temp sitting at 16 and mobo @ 34)
I'm happy, and a little disappointed at the same time, but I maybe simply doing something st00pid to not allow me to go any further.
Current stats are:
CPU: Q6600
Mobo: Asus P5K Premium
RAM: GSkill DDR2 PC8500 (4GB - 2 x 2GB)
FSB set to 356
Multi set to 9
Core speed 3200mhz
CPU Voltage: 1.325
CPU-Z reports things slightly differently (seems to think core speed is 2136 as my Bus Speed is x 6.0??? Not sure why that is!?
I set my Ram voltage to 2.05 (it apparently is rated at 2 - 2.1v) so I went for the middle! (memtest reports no errors)
If I push it higher (even a FSB of 360) it stacks it after about 10-20min of Prime95. Yet in its current guise it is Prime95 stable for 12hours (I stopped it after that).
Any ideas how I can push it a bit higher? I've seen people with the same CPU, cooler etc fairly easily hit 3.5-6 on air - only I'm not 100% sure what I'm doing, and I'm sure the voltage is already quite high for its current clock!
Many thanks for any advice (again!!!
[EDIT: and thanks for the advice earlier, I've moved GFX card to primary PCI-E port, replaced all SATA cables with right angled ones and replaced the fan in the Tuniq Tower for a Noctua version)
Current stats are:
CPU: Q6600
FSB set to 356
Multi set to 9
Core speed 3200mhz
CPU Voltage: 1.325
)[EDIT: and thanks for the advice earlier, I've moved GFX card to primary PCI-E port, replaced all SATA cables with right angled ones and replaced the fan in the Tuniq Tower for a Noctua version)
load line calibration is working much better for you than it did for me!!
