Early high mileage 540i's can go for as low as £1500-2000. He had added the cosmetics to make it look up to date
True, it was totally stock when I got it, a few quid later and it got a face lift. Makes the car look loads different!
Pinter - where did you get your new lights from, and did you have to do any additional wiring or fiddling to get the angel eyes to work on your '97?
Im currently looking around at the 535i and the 540i
Slightly OT, but may be in the interest of OP, if you own a BMW which is 4-6 years old, do you still get it serviced at a BMW dealer for the stamps? or just a specialist? Is there a HUGE price difference?
2.5k for that is a steal.I have a 540i (1997) and it is a super sweet car!
I am 33 (As of the 11th Apr) with 7yrs protected NCB and with no excess, I pay £550 FC. It is parked on the road tho'.
Common faults on the V8's - Crap cooling system. Before I got it the expansion tank was replaced. Since I have had it, the rad plastic coupling broke, then the top hose split! Nothing too heinous. Rad was £100 odd and the hose £18.
Over the near 2 years I have had it, I have had to replace the camshaft sensor, £80 5 min DIY job. Also it blew a fuel line (the rubber coupling), again a quick DIY job. Most of the things that are failing are made of rubber, simply due to age.
I think I do need my prop shaft donut doing, but this does not really affect the day to day use.
I got it for £2500 and it has now 197,000 miles on it. Today it still drives great, and is very very very fast. I do not drive it everyday, and when I do it probably only does <10 miles a week. If I wanted a daily driver, I would not have the 540i
MPG is horrible. Best I have had in town is 21mpg that is with free moving traffic and most lights on green.
I did add a sport front bumper OEM, new alloys and angel eyes OEM.
Overall, it is simply the best car I have ever travelled in. Sport mode makes all the right noises and when you need it to move quickly, it does!
Kickdown in sport is nothing short of brutal!
Before this I have a poverty spec 316i e36, which for 5 years nothing ever went wrong!
