- 4 Apr 2003
[TW]Fox;11437145 said:People say this and I wish it was true, becuase I'd love to buy something like an ST with 'serious miles' on it for nowt. Unfortunately it never seems to happen, they still cost thousands![]()
Reason is most performance cars worth having will hold their value reasonable well as they get older. After the main hit of depreciation over the first 3-5 years, the depreciation slows down.
Unfortunately for these sorts of cars by the time they depreciate to a point where they seem really cheap, they are no longer worth buying and will hit you with either a stack of repair bills or simply give up the ghost.
The average run of the mill car however seems to plod on and on with lower repair costs and ultimately costs little to buy.
The exception is where you find much older vroom vroom cars say 8+ years with low mileage, well looked after and got life in them where the value through age is intrinsically lower but then they are still worth buying.
As for the OP, take a look at volvo S60s, you should find some to fit your criteria. Possibly even a T5.
