Mates sister off limits?
i have done a mates sister before. he didnt like it first of all but just got used to the idea.
Does no-one know the unwritten rule? :confused:
Is that the one to do with marriage? If so then yes.
I'd consider going out with a mates sister but I'd be even more careful than normal to be fair towards her and to make sure the mate was ok with it or if not ok then at least understood the situation.
All depends how good a mate he is, this works on both sides A), if your a really good mate to the point he thinks your a bloody decent bloke, he would be happy his sister was dating someone like you.
B),your that good a mate you know he wont punch your lights out when he finds out :)
Basicly do you think your good enough mates to get away with slipping his sister one? id ask my self the same question exactly how ive written it and your answer will most likly be his!
Say it to your self in your head, what would i do if he was slipping my sister one?, if your blood boild tread with caution, though i doubt it will stop you as i know it wouldnt stop me :D
