OK, so it was a long time coming - my mobo has finally just died on me. What a POS it is!
The scenario:
- Just resumed the PC from suspend and then the screen goes blank, and then vista reports that the VGA (NVIDIA) drivers have died on me, the screen still works, can see everything on my pc where i left it, and then proceed to do a restart to fix the problem. (Note that my NIC has also failed.)
- remembering that a later BIOS update had fixed my NIC troubles, I proceeded to launching into the BIOS updater program (ALT+F2)
- I selected 1101 (latest release) and then it verified the file first - reporting that it found no boot information - An error message.
- I thought this may mean that the data on my USB stick had corrupted somehow, so left this updater after I couldn't update the BIOS.
- I went into my BIOS setup, confirmed everything looked okay in there. and then F10 to save and quit.
- The PC restarts, but nothing is coming up on my monitor, the HDD lights aren't flikering like they used to, and it just hangs there. As i don't have a PC speaker I don't hear any beeps.
- I plug in this stupid LCD poster that came with this mobo, and it goes through, CPU INT, DET DRAM, TEST VRAM etc etc, then BAM - ERRORMSG
- I have unplugged my 8800GTXs, unplugged my X-Fi, re-seated 1 GTX at a time, checked the RAM, checked my HDDs which work elsewhere - no joy.
- I have cleared the CMOS using the button on my I/O ports - no joy
- I have removed the battery, waited a while - no joy
- several restarts - no joy
everytime, nothing on my screen, and this message on my LCD poster - ERRORMSG
So questions:
1. Is there anything that I can do apart from RMA'ing this board - which is what I really should be doing!
2. What alternate mobo should I be considering as this has been nothing apart from a POS, (replacement - DDR2 and SLI essential, although if DDR3 modules are cheap, then a DDR3 mobo will be considered)
your help is appreciated in advance
The scenario:
So questions:
