Ok this is a very annoying one.
Have been running vista ultimate 32bit for months with no problems.
Decided to try upgrading to 64-bit version today.
Vista 64 wouldn't load - bsod . It wouldn't boot to safe mode into safe mode either.
After some reading I thought it might be the 64-bit 4gb issue, so removed 2gb, reformated partition and clean reinstall - no luck exactly the same.
Eventually I decided to give it up and go back to 32-bit.
So again reformat partition and reinstall - now it won't even install 32-bit, bsod half way through installation. 0x0000007a
So clean installed XP, with full format beforehand (which took bloody ages). XP seemed to run fine. So went back for another shot of vista, and again bsod during installation (same error)
So, any ideas out there? This machine has been running ultimate 32 for months with no issues. could initial 64 installation screwed up the bios or something. I've been clean installing so would think any dodgy kernel would have been purged. Also XP is running ok.
The only thing I haven't tried is reformating my second partition (data only - no OS) although I can't see how that would affect the OS boot.
So I'm stuck and annoyed. MS seem to have managed to screw up my machine.
. It could well be a driver conflict somewhere that is causing it to bsod as vista has a lot of drivers built in.
