Hazro Aluminium monitors now available from OcUK!!
OcUK Staff
17 Oct 2002
OcUK HQ
Hi there
Well I promised you that I would get Hazro into OcUK and now its here:-
Hazro HZ23W 23" Widescreen LCD Monitor - Black Aluminium
With vivacious colour reproduction across severe resolutions, and a market-leading extreme viewing perspective, the Hazro HZ23W breeds confidence in colour. Built with you in mind, the panoramic 178-degree viewing perspective brings quality to a wider audience, whether you work as part of a team or just demand control. The aesthetic frame and offset panelling helps dispel heat with optimal efficiency leaving you to concentrate on the work at hand, whilst the touch-screen OSD display streamlines the HZ23W and allows you total control over your visual workspace. Through the toughest work environments, the Hazro HZ23W realises unwavering strength and unparalleled consistent colour reproduction, without sacrificing control over the images you present.
As far as we’re concerned, there’s no substitute for brilliance in visuals. The Hazro HZ23W combines timeless engineering with a passion for colour and clarity, whilst the design ensures it won’t look out of place in the home or office environment. With super-IPS panelling, we take sharpness to the next level, with brightness and rich colour saturation taken as read. Allow your work to breathe, with the ultra-resolution maximum visual workspace. Take your creations where they need to go with full freedom, whilst enjoying the potent colour clarity the HZ23W has to offer. The HZ23W comes equipped with RGB component input, allowing you to adapt to clarity in high definition, as well as making your display compatible with other media formats. The ultra-fast rapid response time prevents ghosting and streaking to allow effortless visual media playback, without taxing the environment, whilst the degree of precision in colour makes the HZ23W ideal for creatives and designers. Amplify your workspace with the Hazro HZ23W. A dense 1920 x 1200 resolution with a 0.258mm pixel pitch delivers perfectly rendered images, every time. With the right balance of physical size to resolution, the HZ23W boasts uncompromising clarity without eyestrain or distortion.
Equally effective wherever it's used, the aluminium casing makes the HZ23W durable and robust enough to be used in any environment. Its aesthetic brilliance is also complimented by the sense of purpose that surrounds each-and-every feature. The rapid response time naturally provides for a seamless viewing experience of high-definition media. This helps to redefine ghosting and streaking as historical problems, also allowing transitions between grey scales to be handled with razor-sharp precision.
- All aluminium finished casing
- Viewable Area: 23” Widescreen (1920x1200 Resolution)
- Interface: Analogue / DVI / Component
- Response Time: 10ms G2G
- Hard coating(3H), Anti-glare treatment of the front polariser
- Contrast Ratio: 700:1
- Viewing Angle (H/V): 178°/ 178°
- Brightness: 500cd/m2
- 3 Years On-Site Swap-Out with Hazro (2nd & 3rd year RTB)
Price: £344.99+VAT (£405.36 inc VAT)
BUY NOW!
Hazro HZ23W 23" Widescreen LCD Monitor - Silver Aluminium
BUY NOW!
Hazro HZ24W 24" Widescreen LCD Monitor - Black Aluminium
Perfection is a rare thing. The Hazro HZ24W combines an unorthodox blend of aesthetics and ultra-performance, with widescreen visibility beyond traditional horizons. That’s why we’re fast becoming recognised at the forefront of the industry. With the series-standard 178-degree viewing perspective, the HZ24W is the ideal solution for creative teams, or for the independent office environment. Enjoy optimal colour saturation and luminance from every angle, with professional-grade resolution designed to enhance creativity and broaden your workspace, whilst reaping the benefits of a new benchmark in LCD display. Combining the visual excellence and graphic detail of the larger models in the range, the new HZ24W brings the fusion of performance and durability you’ve come to expect, without sacrificing appearance. Experience media in high definition with the in-built RGB input, allowing impressive streaming clarity from an almost panoramic view-angle. Forget switching between application windows and endlessly scrolling through text – with the Hazro HZ24W, you can save time and increase productivity with a more than ample viewing area. The Hazro HZ24W is designed to promote durability and efficient heat dissipation, whilst providing uncompromising colour reproduction time after time.
The streamlined design is epitomized in the touch screen OSD, designed to allow total control at your fingertips. When multitonal colour clarity is the order of the day, on screen visual control is paramount to enable you to get the most out of your graphics. The massive resolution amplifies your workspace to encourage freedom, removing the traditional boundaries of the creative process. The ergonomically focused design compliments a severe colour gamut with a rapid response time of 5ms, to ensure smooth greyscale transitions and consistently pure colour reproduction in even the harshest of environments. Impressive graphic rendering meets high colour gamut in one of our easiest to use, most attractive models. When you’ve experienced versatility with strong all-round performance, and distinction through industry-leading S-IPS panelling, there’s no room for second best.
When colour matters, S-IPS active matrix display technology delivers unsurpassed levels of colour saturation, luminance and gamut. It results in image clarity that allows for grey scales to be easily differentiated amongst other colour clusters to bring unheard of precision and accuracy in visual reproduction.
- Viewable Area: 24” Widescreen (1920x1200 Resolution)
- Response Time: 5ms G2G
- 16.7M Colours
- Brightness: 400cd/m2
Price: £374.99+VAT (£440.61 inc VAT)
BUY NOW!
Hazro HZ24W 24" Widescreen LCD Monitor - Silver Aluminium
- 16.7M Colours
BUY NOW!
Hazro HZ26W 26" Widescreen LCD Monitor - Black Aluminium
Boasting an ultra-high resolution S-IPS active matrix display, and an industry-defining 178 degree-viewing angle, the Hazro HZ26W is designed to liberate creativity and enhance innovation. Coloured with clarity, the ergonomically friendly design frames ahead-of-the-class visual technology with laser-point rendering accuracy and 5ms rapid response. From graphics studios to press rooms to the office floor, the Hazro HZ26W redefines the workplace to bring visuals to life. With uncompromising resolution and razor-sharp display, the Hazro HZ26W remains consistent across the harshest work environments. Wherever you’re based, whatever your needs, the Hazro HZ26W sees display technology realise perfection.
With the wide-angled 25.54” working area, and precise colour reproduction, the Hazro HZ26W is favoured by those that demand professional quality visuals and leading-edge technology. With high colour brightness and saturation, the HZ26W guarantees greater fidelity to render visual perfection before your eyes. Whether you’re working alone or as part of a team, the panoramic viewing perspective enables minimal glare and distortion from any position to visually streamline the creative process. The aerodynamic design of the Hazro HZ26W is further enhanced by the touch-screen OSD to enable maximum display efficiency, giving you unparalleled control and input.
Experience a 178 degrees viewing angle from left to right, up and down. Whether your presenting to an audience, or taking advantage of the HZ Range's multiple application inputs to engage in multi-player gaming you will experience the same degree of perfection from all angles. Featuring a massive 1920x1200 resolution (2.3MP), users experience a flicker-free output, that reduces eye-strain and combines with fast response times ( 5ms GTG) to provide seamless viewing of high definition media.
Choosing between the black or sliver aluminium housing, the heat dissipation technology at work in the HZ26W removes the need for cooling vents – thus, increasing the ability for the HZ Range to go to work in the harshest of environments. The design is suitable for sitting on a desktop or attached to a wall for multi-person viewing in any work environment.
- Viewable Area: 26” Widescreen (1920x1200 Resolution)
- 16.7M Colours (92% Colour Gamut)
- Contrast Ratio: 800:1
Price: £499.99+VAT (£587.49 inc VAT)
BUY NOW!
Hazro HZ26W 26" Widescreen LCD Monitor - Silver Aluminium
BUY NOW!
Hazro HZ30W 30" Widescreen LCD Monitor - Black Aluminium
Inspired by professionals, the Hazro HZ30W has been designed and optimised for use in environments where high colour saturation, brightness and gamut are important. Boasting an ultra-high resolution S-IPS active matrix display, the HZ30W offers greater colour fidelity with the least amount of shift; yielding crisper, sharper, clearer and more vibrant images. For the professional, creative boundaries need not be restricted to poor resolutions and narrow viewing angles. The massive 4MP (2560x1600) resolution brings a new dimension to on-screen graphics and enhances productivity. With a workspace three times that of standard 19" monitor you can now simultaneously access all those necessary tools, pallets and windows of your creative applications. Whether youre working alone or as part of a team, the panoramic viewing perspective (178 degrees) enables minimal glare and distortion from any position to visually streamline the creative process. If motion graphics, gaming or video editing is your are area, a super fast 12ms response time ensures rapid interchange between colours as you demand without streaking or ghosting resulting in seamless visual media performance. For the performance-driven individual, the Hazro HZ30W provides the ideal navigation perspective for your desktop in the home or office environment.
As a creative business, we know colour matters. Thats why the Hazro HZ30W delivers nothing short of pure colour reproduction on a consistent basis, allowing you to exercise the full extent of your ability on client projects time and time again. The ultra-fast 12ms response time enables you to view and create streaming media without interruption and with breathtaking clarity, to provide the level of professionalism your clients demand from end output with no question of reliability.
- Viewable Area: 30” Widescreen (2560x1600 Resolution)
- Interface: Analogue / DVI / Component (Digital DVI (Dual Link) - HDCP support)
- Response Time: 6ms G2G (12ms Black to Black)
- Contrast Ratio: 1000:1
- Brightness: 300cd/m2
Price: £849.00+VAT (£997.58 inc VAT)
BUY NOW!
Hazro HZ30W 30" Widescreen LCD Monitor - Silver Aluminium
BUY NOW!
cool to see these here first.
i've been looking at a new 24" monitor and had pretty much settled on the benqfp241w, what's the mileage in looking at an ips over the mva/pva? panel of the benq?
I know the viewing angles are more vivid at the wider angles and the colour reproduction is better on ips panels but i hear the contrast can be lower than other panels. Also what are these panels like for response time/input lag? Any answers would be greatly appreciated, I will be using the monitor for graphics and modelling work and gaming as well and therefore I would be tempted in these monitors if they can handle the gaming side of things as well as the graphics side.
I suggest you look here: http://www.tftcentral.co.uk/
Enjoy
cheers adamcg, i went back and checked out the hazro review which i had not looked at before and found it very helpful =)
yeah robbie, its a real pity that there isnt hdcp
Hi there
I've spoken to Hazro this morning about the pricing on the 24" model and unfortunately they can't do anything, they are informing me their cost to manufacturer that size has rocketed and are even considering pulling the 24" model from the lineup due to the increased cost.
Be a bit silly to pull the 24" as for starters it's a much newer panel than the 23" (23" S-IPS screens are being discontinued by LGP IIRC) and it's still competetively priced against things like the Dell 24" monitors.
How did you get 26" versions?
The guy on the phone made a point of saying those wouldnt be in stock for a couple of months.
Hi there
Because they are taking us as exclusive partner to supply their screens and if you look at our ETA it shows a leadtime of end of May, we will see about 1-2pc of 26" over the next couple of weeks.
Fairly random, yes, but remember that the Apple Cinema Displays come in 20", 23" and 30" so at some point LG probably decided that 23" was the best dot pitch for 1920x1200 resolution. I would imagine that they've now realised that everyone else has gone to 24" and have thus capitulated and done the same.
Couple of questions about the 24 "
The only review I can find is on TFTCentral http://www.tftcentral.co.uk/reviews/hazro_hz24w.htm Who are usually pretty accurate with their reviews
You are advertize the 24" with a 92% colur gamut. The above review states that it only has 72%. Is this a typo or are the newer versions of the 24" going to have a 92% colour gamut ?
TFTCentral said:
While it is not provided at present, plans are to package the Hazro Professional range of monitors with calibration software and hardware colorimeter devices. Around February 2008, the range should come with a software calibration package, under the name of the Hazro Calibration Suite (HCS). Later in the year, there will be a more enhanced version of the screens available with programmable LUT controller boards, and these will come packaged with a more advanced version of the sofware and a colorimeter device. This range is expected around Easter time, and will be a more feature rich and enhanced package
This " enhanced package ". Is this what you will be selling ?
Thanks
I doubt it is, when I spoke to my contact at Hazro he said they haven't yet got the colorimeter package finished, I did glean that it'll be based on BasICColor providing the software.
Thanks for the insight.
Just need to know about the colour gamut.
TFTCentral seem to think its 72%
Its advertized here and on OCUK`s site as 92%
Which is it 72% or 92% ? can anyone clarify ?
From sitting in front of the thing I don't think it's a wide-gamut screen, it's much closer to my old 72% (sRGB) TFT. That's actually a good thing for me, as I do mainly web work (if I do any graphics work, I'm a programmer) and thus don't need the extra gamut for pre-proofing purposes.
