Hi, just a quick q about the above, I've had a look around and can't seem to find a definite answer.
I'm thinking about buying a LCD soon and will be planning on running the PC through it using my HD2900XT. The card came with a DVI to HDMI adapter but I have an aversion to using adapters if possible and seeing as I'll have to buy a HDMI to HDMI lead anyway I am thinking of just buying a DVI to HDMI lead. They're about the same price and it saves using the adapter, so there's one less link in the chain.
Now my question is, if I do it this way will I still get audio over the HDMI? Or does the DVI to HDMI adapter do something that a straight DVI to HDMI lead won't?
The reason I ask is that all DVI to HDMI leads I've seen advertised say they will not carry sound. But they all seem to have the full set of pins at the DVI end.
Also will it all still be HDCP(?) compliant?
Thanks.
Thanks.
