2.1 to amp and bookshelves
24 Apr 2007
Rochford
Evening all :) I'm thinking about going from my current 2.1 Creative set up (L3800) to a Cambridge Audio A5 and 2 possibly Mordaunt Short 902i's. I listen to a range of music, from dance to metal, and also game with them. Would this upgrade be worth it in peoples opinions? Will I get a better sound quality?
Naud
I bought the 902i's from Richer sounds for £149.00 last week, then found them at Hifix for £109.00, sent an e-mail to RS about their "price beat" and they gave me back the £40 difference plus £10:).
Very happy with the speakers and a big thanks to RS.
Awesome, will go ahead with it then, the only thing I'm wondering about is the speakers, I'm also quite a fan of the Kef Crestas
Naud
Yeah RS should do it for me, gonna head in there when I get back from Uni and check them out. Anyone use the Kef Crestas? Peoples thoughts on them would be good
Naud
Second hand is also something to consider. I bought b&w 601 s2's new two years ago for £250, theyre now going second hand for around 100! Theyre excellent speakers and I'm only upgrading them now after all this time.
Sounds identical to my setup. :D They work a treat! Just going to buy the Mordaunt Short sub to go with them and I think I'll be sorted! :D
Most certainly - Welcome to the expensive world of hi-fi :D
Doesn't have to be expensive imo if you go second hand.
I got some Mission 761's, Marantz PM-66SE integrated amp and Denon tuner for under £90.
This is my first effort at Hi-Fi, and so far I'm loving the sound :D
Firegod, you running the A5 as an amp as well then?
Naud
Cambridge Audio Azur 640A + x2 Mordaunt Short 902i's. Just purchased the 309i sub tonight to go with them. hehe :D
Been really pleased with them for listening to music, etc from the PC. :) Can't wait to get full 2.1 sound. Should be good!
Yeah was looking at that amp as well, although it is a little out of my price range. Shame, coz it does look the sex
Naud
